Time Before: 0.00155 seconds
Time After: 0.00212 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00219 seconds
Time After: 0.00255 seconds
Time Before: 0.00292 seconds
Time After: 0.00309 seconds
Time Before: 0.00404 seconds
Time After: 0.00753 seconds
Time Taken: 0.00349 seconds
Time Before: 0.00319 seconds
Time After: 0.01250 seconds
Time Taken: 0.00931 seconds
Time Before: 0.01570 seconds
Time After: 0.01616 seconds
Time Before: 0.01757 seconds
Time After: 0.01896 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01487 seconds
Time After: 0.01914 seconds
Time Taken: 0.00427 seconds
Time Before: 0.02623 seconds
Time After: 0.02659 seconds
Time Before: 0.03019 seconds
Time After: 0.03284 seconds
Time Taken: 0.00265 seconds
End call of global.php: 0.035614013671875
Time Before: 0.03731 seconds
Time After: 0.03747 seconds
Time Before: 0.04046 seconds
Time After: 0.04235 seconds
Time Taken: 0.00189 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=6708', badlocation = 1
WHERE sessionhash = '87651ca345a619a09949038b7f47c9ec'
Time Before: 0.05641 seconds
Time After: 0.05702 seconds
Time Taken: 0.00061 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
Page generated in 0.055475950241089 seconds with 9 queries, spending 0.011522054672241 doing MySQL queries and 0.043953895568848 doing PHP things.
