Time Before: 0.00720 seconds
Time After: 0.01001 seconds
Time Taken: 0.00281 seconds
Time Before: 0.01011 seconds
Time After: 0.01057 seconds
Time Before: 0.01084 seconds
Time After: 0.01098 seconds
Time Before: 0.01177 seconds
Time After: 0.01458 seconds
Time Before: 0.01104 seconds
Time After: 0.01989 seconds
Time Taken: 0.00884 seconds
Time Before: 0.02377 seconds
Time After: 0.02423 seconds
Time Before: 0.02561 seconds
Time After: 0.02696 seconds
Time Taken: 0.00136 seconds
Time Before: 0.02309 seconds
Time After: 0.02717 seconds
Time Taken: 0.00408 seconds
Time Before: 0.04479 seconds
Time After: 0.04493 seconds
Time Before: 0.05217 seconds
Time After: 0.05351 seconds
Time Taken: 0.00134 seconds
Time Before: 0.05967 seconds
Time After: 0.05985 seconds
Time Before: 0.06230 seconds
Time After: 0.06375 seconds
UPDATE session SET lastactivity = 1783038358, location = '/forums/private.php?do=newpm&explain=1&u=67132' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.08220 seconds
Time After: 0.08250 seconds
Memory Before: 4,288.313 KB
Memory After: 4,288.539 KB
