Time Before: 0.02243 seconds
Time After: 0.03283 seconds
Time Taken: 0.01040 seconds
Time Before: 0.03293 seconds
Time After: 0.03335 seconds
Time Before: 0.03359 seconds
Time After: 0.03374 seconds
Time Before: 0.03450 seconds
Time After: 0.03665 seconds
Time Taken: 0.00215 seconds
Time Before: 0.03380 seconds
Time After: 0.04079 seconds
Time Taken: 0.00700 seconds
Time Before: 0.04917 seconds
Time After: 0.04955 seconds
Time Before: 0.05201 seconds
Time After: 0.05324 seconds
Time Before: 0.04838 seconds
Time After: 0.05347 seconds
Time Taken: 0.00509 seconds
Time Before: 0.08643 seconds
Time After: 0.08660 seconds
Time Before: 0.10573 seconds
Time After: 0.10700 seconds
Time Before: 0.11717 seconds
Time After: 0.11748 seconds
Time Before: 0.12036 seconds
Time After: 0.12190 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=67199', badlocation = 1 WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.13937 seconds
Time After: 0.13975 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
