Time Before: 0.00139 seconds
Time After: 0.00187 seconds
Time Before: 0.00195 seconds
Time After: 0.00270 seconds
Time Taken: 0.00075 seconds
Time Before: 0.00303 seconds
Time After: 0.00331 seconds
Time Before: 0.00403 seconds
Time After: 0.00677 seconds
Time Taken: 0.00274 seconds
Time Before: 0.00337 seconds
Time After: 0.01055 seconds
Time Taken: 0.00718 seconds
Time Before: 0.01261 seconds
Time After: 0.01301 seconds
Time Before: 0.01556 seconds
Time After: 0.01693 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01189 seconds
Time After: 0.01711 seconds
Time Taken: 0.00522 seconds
Time Before: 0.02214 seconds
Time After: 0.02233 seconds
Time Before: 0.02409 seconds
Time After: 0.02534 seconds
End call of global.php: 0.026926040649414
Time Before: 0.02843 seconds
Time After: 0.02862 seconds
Time Before: 0.03089 seconds
Time After: 0.03238 seconds
SET lastactivity = 1788883684, location = '/forums/private.php?do=newpm&explain=1&u=67213', badlocation = 1
Time Before: 0.04622 seconds
Time After: 0.04661 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.045233011245728 seconds with 9 queries, spending 0.0090410709381104 doing MySQL queries and 0.036191940307617 doing PHP things.
