Time Before: 0.03716 seconds
Time After: 0.05250 seconds
Time Taken: 0.01534 seconds
Time Before: 0.05260 seconds
Time After: 0.05301 seconds
Time Before: 0.05332 seconds
Time After: 0.05347 seconds
Time Before: 0.05442 seconds
Time After: 0.05661 seconds
Time Taken: 0.00219 seconds
Time Before: 0.05354 seconds
Time After: 0.06103 seconds
Time Taken: 0.00749 seconds
Time Before: 0.07971 seconds
Time After: 0.07995 seconds
Time Before: 0.08296 seconds
Time After: 0.08418 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.07883 seconds
Time After: 0.08444 seconds
Time Taken: 0.00561 seconds
Memory After: 2,261.836 KB
Time Before: 0.15926 seconds
Time After: 0.15942 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"20.70,\";s:9:\"lastcheck\";i:1789056519;}', 1)
Time Before: 0.18094 seconds
Time After: 0.18137 seconds
Memory Before: 2,816.625 KB
Memory After: 2,816.875 KB
Memory Used: 0.250 KB
Time Before: 0.20145 seconds
Time After: 0.20274 seconds
Memory Before: 2,903.930 KB
Memory After: 2,904.523 KB
End call of global.php: 0.20586395263672
Time Before: 0.22094 seconds
Time After: 0.22108 seconds
Memory Before: 3,540.734 KB
Memory After: 3,541.164 KB
Time Before: 0.22385 seconds
Time After: 0.22538 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,822.313 KB
Memory After: 3,824.000 KB
SET lastactivity = 1789056519, location = '/forums/private.php?do=newpm&explain=1&u=67320', badlocation = 1
Time Before: 0.24842 seconds
Time After: 0.24873 seconds
Memory Before: 4,296.430 KB
Memory After: 4,296.641 KB
Page generated in 0.24728512763977 seconds with 10 queries, spending 0.0080931186676025 doing MySQL queries and 0.23919200897217 doing PHP things.
