Time Before: 0.00135 seconds
Time After: 0.00185 seconds
Time Before: 0.00192 seconds
Time After: 0.00234 seconds
Time Before: 0.00254 seconds
Time After: 0.00268 seconds
Time Before: 0.00336 seconds
Time After: 0.00551 seconds
Time Taken: 0.00214 seconds
Time Before: 0.00273 seconds
Time After: 0.00896 seconds
Time Taken: 0.00623 seconds
Time Before: 0.01078 seconds
Time After: 0.01115 seconds
Time Before: 0.01359 seconds
Time After: 0.01573 seconds
Time Before: 0.01021 seconds
Time After: 0.01592 seconds
Time Taken: 0.00570 seconds
Time Before: 0.02084 seconds
Time After: 0.02096 seconds
Time Before: 0.02282 seconds
Time After: 0.02407 seconds
Time Before: 0.02706 seconds
Time After: 0.02722 seconds
Time Before: 0.03013 seconds
Time After: 0.03157 seconds
UPDATE session SET lastactivity = 1785361256, location = '/forums/private.php?do=newpm&explain=1&u=67356' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04433 seconds
Time After: 0.04473 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
