Time Before: 0.02527 seconds
Time After: 0.03454 seconds
Time Taken: 0.00927 seconds
Time Before: 0.03463 seconds
Time After: 0.03504 seconds
Time Before: 0.03533 seconds
Time After: 0.03546 seconds
Time Before: 0.03639 seconds
Time After: 0.03884 seconds
Time Taken: 0.00245 seconds
Time Before: 0.03554 seconds
Time After: 0.04364 seconds
Time Taken: 0.00810 seconds
Time Before: 0.05150 seconds
Time After: 0.05170 seconds
Time Before: 0.05489 seconds
Time After: 0.05607 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05077 seconds
Time After: 0.05632 seconds
Time Taken: 0.00555 seconds
Time Before: 0.09854 seconds
Time After: 0.09870 seconds
Time Before: 0.11786 seconds
Time After: 0.11910 seconds
End call of global.php: 0.12123799324036
Time Before: 0.12879 seconds
Time After: 0.12896 seconds
Time Before: 0.13152 seconds
Time After: 0.13304 seconds
Time Taken: 0.00152 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=67378'
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.15293 seconds
Time After: 0.15326 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.15173697471619 seconds with 9 queries, spending 0.0077898502349854 doing MySQL queries and 0.1439471244812 doing PHP things.
