Time Before: 0.00134 seconds
Time After: 0.00180 seconds
Time Before: 0.00194 seconds
Time After: 0.00239 seconds
Time Before: 0.00261 seconds
Time After: 0.00275 seconds
Time Before: 0.00345 seconds
Time After: 0.00831 seconds
Time Taken: 0.00486 seconds
Time Before: 0.00280 seconds
Time After: 0.01174 seconds
Time Taken: 0.00894 seconds
Time Before: 0.01402 seconds
Time After: 0.01450 seconds
Time Before: 0.01714 seconds
Time After: 0.01852 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01328 seconds
Time After: 0.01870 seconds
Time Taken: 0.00542 seconds
Time Before: 0.02558 seconds
Time After: 0.02572 seconds
Time Before: 0.02770 seconds
Time After: 0.02901 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03226 seconds
Time After: 0.03249 seconds
Time Before: 0.03478 seconds
Time After: 0.03630 seconds
Time Taken: 0.00152 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=67419' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04890 seconds
Time After: 0.04924 seconds
Memory Before: 4,910.828 KB
Memory After: 4,911.070 KB
