Time Before: 0.01877 seconds
Time After: 0.02657 seconds
Time Taken: 0.00780 seconds
Time Before: 0.02668 seconds
Time After: 0.02714 seconds
Time Before: 0.02743 seconds
Time After: 0.02757 seconds
Time Before: 0.02839 seconds
Time After: 0.03182 seconds
Time Taken: 0.00343 seconds
Time Before: 0.02763 seconds
Time After: 0.03576 seconds
Time Taken: 0.00813 seconds
Time Before: 0.04468 seconds
Time After: 0.04587 seconds
Time Before: 0.04935 seconds
Time After: 0.05055 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04289 seconds
Time After: 0.05078 seconds
Time Taken: 0.00789 seconds
Memory After: 2,261.719 KB
Time Before: 0.07888 seconds
Time After: 0.07904 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.09724 seconds
Time After: 0.09855 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
End call of global.php: 0.10053491592407
Time Before: 0.10986 seconds
Time After: 0.11002 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.11268 seconds
Time After: 0.11411 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=67434', badlocation = 1
Time Before: 0.13114 seconds
Time After: 0.13140 seconds
Memory Before: 4,287.500 KB
Memory After: 4,287.727 KB
Page generated in 0.12999582290649 seconds with 9 queries, spending 0.0097277164459229 doing MySQL queries and 0.12026810646057 doing PHP things.
