Time Before: 0.00135 seconds
Time After: 0.00183 seconds
Time Before: 0.00190 seconds
Time After: 0.00234 seconds
Time Before: 0.00256 seconds
Time After: 0.00269 seconds
Time Before: 0.00336 seconds
Time After: 0.00595 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00274 seconds
Time After: 0.00970 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01139 seconds
Time After: 0.01173 seconds
Time Before: 0.01440 seconds
Time After: 0.01562 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01086 seconds
Time After: 0.01587 seconds
Time Taken: 0.00501 seconds
Memory After: 2,261.836 KB
Time Before: 0.02250 seconds
Time After: 0.02264 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
Time Before: 0.02496 seconds
Time After: 0.02650 seconds
Time Taken: 0.00154 seconds
Memory Before: 2,903.570 KB
Memory After: 2,904.164 KB
Time Before: 0.02974 seconds
Time After: 0.02993 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.03278 seconds
Time After: 0.03432 seconds
Memory Before: 3,821.906 KB
Memory After: 3,823.594 KB
UPDATE session SET lastactivity = 1789147702, location = '/forums/private.php?do=newpm&explain=1&u=67470', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04990 seconds
Time After: 0.05019 seconds
Memory Before: 4,287.859 KB
Memory After: 4,288.070 KB
