Time Before: 0.02710 seconds
Time After: 0.03237 seconds
Time Taken: 0.00527 seconds
Time Before: 0.03245 seconds
Time After: 0.03287 seconds
Time Before: 0.03309 seconds
Time After: 0.03322 seconds
Time Before: 0.03404 seconds
Time After: 0.03678 seconds
Time Taken: 0.00274 seconds
Time Before: 0.03328 seconds
Time After: 0.04210 seconds
Time Taken: 0.00882 seconds
Time Before: 0.05415 seconds
Time After: 0.05433 seconds
Time Before: 0.05621 seconds
Time After: 0.05741 seconds
Time Before: 0.05333 seconds
Time After: 0.05759 seconds
Time Taken: 0.00426 seconds
Time Before: 0.10135 seconds
Time After: 0.10153 seconds
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"38.19,\";s:9:\"lastcheck\";i:1783055243;}', 1)Time Before: 0.12307 seconds
Time After: 0.12333 seconds
Memory Before: 2,817.273 KB
Memory After: 2,817.523 KB
Memory Used: 0.250 KB
Time Before: 0.14615 seconds
Time After: 0.14739 seconds
Memory Before: 2,904.578 KB
Memory After: 2,905.172 KB
Time Before: 0.15957 seconds
Time After: 0.15974 seconds
Memory Before: 3,541.367 KB
Memory After: 3,541.797 KB
Time Before: 0.16256 seconds
Time After: 0.16414 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,823.109 KB
Memory After: 3,824.797 KB
UPDATE session SET lastactivity = 1783055243, location = '/forums/private.php?do=newpm&explain=1&u=67492', badlocation = 1 WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.18442 seconds
Time After: 0.18467 seconds
Memory Before: 4,297.070 KB
Memory After: 4,297.281 KB
