Time Before: 0.00159 seconds
Time After: 0.00233 seconds
Time Taken: 0.00074 seconds
Time Before: 0.00241 seconds
Time After: 0.00290 seconds
Time Before: 0.00319 seconds
Time After: 0.00333 seconds
Time Before: 0.00426 seconds
Time After: 0.00726 seconds
Time Taken: 0.00300 seconds
Time Before: 0.00340 seconds
Time After: 0.01065 seconds
Time Taken: 0.00725 seconds
Time Before: 0.01256 seconds
Time After: 0.01295 seconds
Time Before: 0.01596 seconds
Time After: 0.01720 seconds
Memory Before: 2,148.953 KB
Memory After: 2,148.813 KB
Time Before: 0.01193 seconds
Time After: 0.01745 seconds
Time Taken: 0.00551 seconds
Memory After: 2,261.836 KB
Time Before: 0.02355 seconds
Time After: 0.02386 seconds
Memory Before: 2,815.359 KB
Memory After: 2,815.875 KB
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"32.50,\";s:9:\"lastcheck\";i:1788912199;}', 1)Time Before: 0.02937 seconds
Time After: 0.02996 seconds
Time Taken: 0.00060 seconds
Memory Before: 2,816.625 KB
Memory After: 2,816.875 KB
Memory Used: 0.250 KB
Time Before: 0.03216 seconds
Time After: 0.03357 seconds
Memory Before: 2,903.930 KB
Memory After: 2,904.523 KB
Time Before: 0.03753 seconds
Time After: 0.03774 seconds
Memory Before: 3,540.734 KB
Memory After: 3,541.164 KB
Time Before: 0.04026 seconds
Time After: 0.04174 seconds
Memory Before: 3,822.313 KB
Memory After: 3,824.000 KB
UPDATE session SET lastactivity = 1788912199, location = '/forums/private.php?do=newpm&explain=1&u=67494' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.05443 seconds
Time After: 0.05476 seconds
Memory Before: 4,296.148 KB
Memory After: 4,296.375 KB
