Time Before: 0.00131 seconds
Time After: 0.00175 seconds
Time Before: 0.00182 seconds
Time After: 0.00225 seconds
Time Before: 0.00246 seconds
Time After: 0.00259 seconds
Time Before: 0.00327 seconds
Time After: 0.00550 seconds
Time Taken: 0.00223 seconds
Time Before: 0.00264 seconds
Time After: 0.00859 seconds
Time Taken: 0.00596 seconds
Time Before: 0.01025 seconds
Time After: 0.01065 seconds
Time Before: 0.01379 seconds
Time After: 0.01512 seconds
Time Taken: 0.00133 seconds
Time Before: 0.00968 seconds
Time After: 0.01533 seconds
Time Taken: 0.00565 seconds
Time Before: 0.02076 seconds
Time After: 0.02087 seconds
Time Before: 0.02305 seconds
Time After: 0.02430 seconds
End call of global.php: 0.025849103927612
Time Before: 0.02724 seconds
Time After: 0.02738 seconds
Time Before: 0.02984 seconds
Time After: 0.03154 seconds
Time Taken: 0.00170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=67597', badlocation = 1
Time Before: 0.04447 seconds
Time After: 0.04475 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
Page generated in 0.043599128723145 seconds with 9 queries, spending 0.0080251693725586 doing MySQL queries and 0.035573959350586 doing PHP things.
