Time Before: 0.00506 seconds
Time After: 0.00710 seconds
Time Taken: 0.00204 seconds
Time Before: 0.00721 seconds
Time After: 0.00763 seconds
Time Before: 0.00789 seconds
Time After: 0.00802 seconds
Time Before: 0.00894 seconds
Time After: 0.01338 seconds
Time Taken: 0.00444 seconds
Time Before: 0.00810 seconds
Time After: 0.01892 seconds
Time Taken: 0.01082 seconds
Time Before: 0.02237 seconds
Time After: 0.02279 seconds
Time Before: 0.02565 seconds
Time After: 0.02685 seconds
Time Before: 0.02176 seconds
Time After: 0.02702 seconds
Time Taken: 0.00526 seconds
Time Before: 0.04237 seconds
Time After: 0.04250 seconds
Time Before: 0.04785 seconds
Time After: 0.04916 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.05184006690979
Time Before: 0.05350 seconds
Time After: 0.05368 seconds
Time Before: 0.05657 seconds
Time After: 0.05806 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=67633'
Time Before: 0.07539 seconds
Time After: 0.07562 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.074472904205322 seconds with 9 queries, spending 0.0099599361419678 doing MySQL queries and 0.064512968063354 doing PHP things.
