Time Before: 0.00785 seconds
Time After: 0.00980 seconds
Time Taken: 0.00195 seconds
Time Before: 0.00990 seconds
Time After: 0.01031 seconds
Time Before: 0.01052 seconds
Time After: 0.01065 seconds
Time Before: 0.01152 seconds
Time After: 0.01390 seconds
Time Taken: 0.00239 seconds
Time Before: 0.01072 seconds
Time After: 0.01812 seconds
Time Taken: 0.00741 seconds
Time Before: 0.02143 seconds
Time After: 0.02179 seconds
Time Before: 0.02319 seconds
Time After: 0.02435 seconds
Time Taken: 0.00116 seconds
Time Before: 0.02083 seconds
Time After: 0.02452 seconds
Time Taken: 0.00369 seconds
Time Before: 0.03783 seconds
Time After: 0.03796 seconds
Time Before: 0.04480 seconds
Time After: 0.04609 seconds
Time Before: 0.05196 seconds
Time After: 0.05210 seconds
Time Before: 0.05433 seconds
Time After: 0.05577 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=67639' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.07323 seconds
Time After: 0.07352 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
