Time Before: 0.00147 seconds
Time After: 0.00195 seconds
Time Before: 0.00202 seconds
Time After: 0.00273 seconds
Time Taken: 0.00071 seconds
Time Before: 0.00303 seconds
Time After: 0.00318 seconds
Time Before: 0.00388 seconds
Time After: 0.00674 seconds
Time Taken: 0.00286 seconds
Time Before: 0.00323 seconds
Time After: 0.01013 seconds
Time Taken: 0.00690 seconds
Time Before: 0.01196 seconds
Time After: 0.01223 seconds
Time Before: 0.01457 seconds
Time After: 0.01588 seconds
Time Taken: 0.00131 seconds
Time Before: 0.01132 seconds
Time After: 0.01605 seconds
Time Taken: 0.00473 seconds
Time Before: 0.02236 seconds
Time After: 0.02257 seconds
Time Before: 1.32621 seconds
Time After: 1.32817 seconds
Time Taken: 0.00196 seconds
Time Before: 1.33202 seconds
Time After: 1.33217 seconds
Time Before: 1.33493 seconds
Time After: 1.33660 seconds
Time Taken: 0.00167 seconds
UPDATE session SET lastactivity = 1776471807, location = '/forums/private.php?do=newpm&explain=1&u=67776', badlocation = 1 WHERE sessionhash = '0d59333b9979c57800f17621ab8164fa'
Time Before: 1.35247 seconds
Time After: 1.35274 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
