Time Before: 0.00344 seconds
Time After: 0.00399 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00407 seconds
Time After: 0.00451 seconds
Time Before: 0.00469 seconds
Time After: 0.00489 seconds
Time Before: 0.00568 seconds
Time After: 0.00852 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00497 seconds
Time After: 0.01193 seconds
Time Taken: 0.00696 seconds
Time Before: 0.01464 seconds
Time After: 0.01507 seconds
Time Before: 0.01759 seconds
Time After: 0.01940 seconds
Time Taken: 0.00181 seconds
Time Before: 0.01407 seconds
Time After: 0.01965 seconds
Time Taken: 0.00558 seconds
Time Before: 0.02986 seconds
Time After: 0.03016 seconds
Time Before: 0.03355 seconds
Time After: 0.03490 seconds
Time Taken: 0.00135 seconds
End call of global.php: 0.037048101425171
Time Before: 0.03863 seconds
Time After: 0.03880 seconds
Time Before: 0.04105 seconds
Time After: 0.04247 seconds
SET lastactivity = 1784826440, location = '/forums/private.php?do=newpm&explain=1&u=67814', badlocation = 1
Time Before: 0.05555 seconds
Time After: 0.05598 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.054184198379517 seconds with 9 queries, spending 0.0093851089477539 doing MySQL queries and 0.044799089431763 doing PHP things.
