Time Before: 0.00186 seconds
Time After: 0.00252 seconds
Time Taken: 0.00066 seconds
Time Before: 0.00262 seconds
Time After: 0.00300 seconds
Time Before: 0.00321 seconds
Time After: 0.00332 seconds
Time Before: 0.00413 seconds
Time After: 0.00742 seconds
Time Taken: 0.00329 seconds
Time Before: 0.00340 seconds
Time After: 0.01087 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01322 seconds
Time After: 0.01357 seconds
Time Before: 0.01593 seconds
Time After: 0.01722 seconds
Time Before: 0.01247 seconds
Time After: 0.01751 seconds
Time Taken: 0.00504 seconds
Time Before: 0.02516 seconds
Time After: 0.02529 seconds
Time Before: 0.02761 seconds
Time After: 0.02887 seconds
Time Before: 0.03238 seconds
Time After: 0.03251 seconds
Time Before: 0.03443 seconds
Time After: 0.03597 seconds
Time Taken: 0.00155 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=67913', badlocation = 1 WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.04990 seconds
Time After: 0.05016 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
