Time Before: 0.00214 seconds
Time After: 0.00264 seconds
Time Before: 0.00271 seconds
Time After: 0.00321 seconds
Time Before: 0.00345 seconds
Time After: 0.00360 seconds
Time Before: 0.00451 seconds
Time After: 0.00704 seconds
Time Taken: 0.00253 seconds
Time Before: 0.00368 seconds
Time After: 0.01060 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01247 seconds
Time After: 0.01290 seconds
Time Before: 0.01542 seconds
Time After: 0.01666 seconds
Time Before: 0.01191 seconds
Time After: 0.01684 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02192 seconds
Time After: 0.02204 seconds
Time Before: 0.02407 seconds
Time After: 0.02529 seconds
End call of global.php: 0.026911973953247
Time Before: 0.02825 seconds
Time After: 0.02845 seconds
Time Before: 0.03058 seconds
Time After: 0.03204 seconds
SET lastactivity = 1776514735, location = '/forums/private.php?do=newpm&explain=1&u=6794', badlocation = 1
Time Before: 0.04448 seconds
Time After: 0.04473 seconds
Memory Before: 4,288.563 KB
Memory After: 4,288.773 KB
Page generated in 0.043582916259766 seconds with 9 queries, spending 0.0081069469451904 doing MySQL queries and 0.035475969314575 doing PHP things.
