Time Before: 0.00267 seconds
Time After: 0.00345 seconds
Time Taken: 0.00078 seconds
Memory Before: 1,244.109 KB
Memory After: 1,270.914 KB
Time Before: 0.00352 seconds
Time After: 0.00398 seconds
Memory Before: 1,270.875 KB
Memory After: 1,271.852 KB
Time Before: 0.00419 seconds
Time After: 0.00433 seconds
Memory Before: 1,272.492 KB
Memory After: 1,273.016 KB
Time Before: 0.00503 seconds
Time After: 0.00782 seconds
Time Taken: 0.00278 seconds
Memory Before: 1,275.883 KB
Memory After: 1,276.805 KB
Time Before: 0.00441 seconds
Time After: 0.01194 seconds
Time Taken: 0.00752 seconds
Memory Before: 1,272.297 KB
Memory After: 2,353.500 KB
Memory Used: 1,081.203 KB
Time Before: 0.01454 seconds
Time After: 0.01496 seconds
Memory Before: 2,893.758 KB
Memory After: 2,894.375 KB
Time Before: 0.01755 seconds
Time After: 0.01888 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,906.203 KB
Memory After: 2,906.063 KB
Time Before: 0.01374 seconds
Time After: 0.01918 seconds
Time Taken: 0.00543 seconds
Memory Before: 2,886.484 KB
Memory After: 3,019.445 KB
Memory Used: 132.961 KB
Time Before: 0.02774 seconds
Time After: 0.02793 seconds
Memory Before: 3,654.031 KB
Memory After: 3,654.547 KB
Time Before: 0.03612 seconds
Time After: 0.03748 seconds
Time Taken: 0.00135 seconds
Memory Before: 4,131.695 KB
Memory After: 4,132.289 KB
End call of global.php: 0.040047883987427
Time Before: 0.04779 seconds
Time After: 0.04803 seconds
Memory Before: 5,195.781 KB
Memory After: 5,324.125 KB
Time Before: 0.05027 seconds
Time After: 0.05205 seconds
Time Taken: 0.00179 seconds
Memory Before: 5,479.469 KB
Memory After: 5,609.070 KB
SET lastactivity = 1772761326, location = '/forums/private.php?do=newpm&explain=1&u=68019', badlocation = 1
Time Before: 0.06710 seconds
Time After: 0.06737 seconds
Memory Before: 6,008.969 KB
Memory After: 6,009.164 KB
Memory Used: 0.195 KB
Page generated in 0.066202878952026 seconds with 9 queries, spending 0.0089797973632812 doing MySQL queries and 0.057223081588745 doing PHP things.
