Time Before: 0.00157 seconds
Time After: 0.00210 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.00217 seconds
Time After: 0.00262 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.00288 seconds
Time After: 0.00303 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.00383 seconds
Time After: 0.00593 seconds
Time Taken: 0.00210 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.00311 seconds
Time After: 0.01141 seconds
Time Taken: 0.00830 seconds
Memory Before: 560.883 KB
Memory After: 1,641.914 KB
Time Before: 0.01375 seconds
Time After: 0.01422 seconds
Time Before: 0.01777 seconds
Time After: 0.01903 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01308 seconds
Time After: 0.01928 seconds
Time Taken: 0.00620 seconds
Memory After: 2,261.820 KB
Time Before: 0.02585 seconds
Time After: 0.02601 seconds
Memory Before: 2,815.414 KB
Memory After: 2,815.930 KB
Time Before: 0.02818 seconds
Time After: 0.02940 seconds
Memory Before: 2,903.719 KB
Memory After: 2,904.313 KB
End call of global.php: 0.031055927276611
Time Before: 0.03251 seconds
Time After: 0.03272 seconds
Memory Before: 3,540.484 KB
Memory After: 3,540.914 KB
Time Before: 0.03538 seconds
Time After: 0.03680 seconds
Memory Before: 3,822.031 KB
Memory After: 3,823.703 KB
Memory Used: 1.672 KB
SET lastactivity = 1783068032, location = '/forums/private.php?do=newpm&explain=1&u=68120'
Time Before: 0.05003 seconds
Time After: 0.05037 seconds
Memory Before: 4,296.703 KB
Memory After: 4,296.930 KB
Page generated in 0.049108982086182 seconds with 9 queries, spending 0.0077788829803467 doing MySQL queries and 0.041330099105835 doing PHP things.
