Time Before: 0.01746 seconds
Time After: 0.02520 seconds
Time Taken: 0.00774 seconds
Time Before: 0.02529 seconds
Time After: 0.02575 seconds
Time Before: 0.02602 seconds
Time After: 0.02617 seconds
Time Before: 0.02700 seconds
Time After: 0.02958 seconds
Time Taken: 0.00258 seconds
Time Before: 0.02625 seconds
Time After: 0.03327 seconds
Time Taken: 0.00702 seconds
Time Before: 0.04156 seconds
Time After: 0.04182 seconds
Time Before: 0.04334 seconds
Time After: 0.04458 seconds
Time Before: 0.04088 seconds
Time After: 0.04480 seconds
Time Taken: 0.00392 seconds
Time Before: 0.08290 seconds
Time After: 0.08306 seconds
Time Before: 0.09963 seconds
Time After: 0.10092 seconds
Time Before: 0.11665 seconds
Time After: 0.11688 seconds
Time Before: 0.12001 seconds
Time After: 0.12152 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=68170' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.14492 seconds
Time After: 0.14519 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
