Time Before: 0.00159 seconds
Time After: 0.00215 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00222 seconds
Time After: 0.00266 seconds
Time Before: 0.00292 seconds
Time After: 0.00306 seconds
Time Before: 0.00393 seconds
Time After: 0.00664 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00314 seconds
Time After: 0.01121 seconds
Time Taken: 0.00807 seconds
Time Before: 0.01392 seconds
Time After: 0.01440 seconds
Time Before: 0.01682 seconds
Time After: 0.01799 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01322 seconds
Time After: 0.01823 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02466 seconds
Time After: 0.02484 seconds
Time Before: 0.02719 seconds
Time After: 0.02846 seconds
End call of global.php: 0.03095006942749
Time Before: 0.03238 seconds
Time After: 0.03257 seconds
Time Before: 0.03559 seconds
Time After: 0.03701 seconds
SET lastactivity = 1776973537, location = '/forums/private.php?do=newpm&explain=1&u=68283'
WHERE sessionhash = 'df28b2ca2ba03bfc49481a2edca83948'
Time Before: 0.05081 seconds
Time After: 0.05109 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.049861907958984 seconds with 9 queries, spending 0.0083019733428955 doing MySQL queries and 0.041559934616089 doing PHP things.
