Time Before: 0.00771 seconds
Time After: 0.01178 seconds
Time Taken: 0.00408 seconds
Time Before: 0.01186 seconds
Time After: 0.01258 seconds
Time Taken: 0.00072 seconds
Time Before: 0.01291 seconds
Time After: 0.01309 seconds
Time Before: 0.01380 seconds
Time After: 0.01579 seconds
Time Taken: 0.00199 seconds
Time Before: 0.01316 seconds
Time After: 0.02092 seconds
Time Taken: 0.00776 seconds
Time Before: 0.02643 seconds
Time After: 0.02694 seconds
Time Before: 0.02941 seconds
Time After: 0.03061 seconds
Time Before: 0.02571 seconds
Time After: 0.03083 seconds
Time Taken: 0.00512 seconds
Time Before: 0.05566 seconds
Time After: 0.05585 seconds
Time Before: 0.06766 seconds
Time After: 0.06891 seconds
End call of global.php: 0.071014881134033
Time Before: 0.07483 seconds
Time After: 0.07501 seconds
Time Before: 0.07748 seconds
Time After: 0.07896 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=68440', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.10016 seconds
Time After: 0.10045 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.098855972290039 seconds with 9 queries, spending 0.0079786777496338 doing MySQL queries and 0.090877294540405 doing PHP things.
