Time Before: 0.00945 seconds
Time After: 0.01298 seconds
Time Taken: 0.00353 seconds
Time Before: 0.01308 seconds
Time After: 0.01360 seconds
Time Before: 0.01385 seconds
Time After: 0.01398 seconds
Time Before: 0.01489 seconds
Time After: 0.01720 seconds
Time Taken: 0.00232 seconds
Time Before: 0.01405 seconds
Time After: 0.02134 seconds
Time Taken: 0.00729 seconds
Time Before: 0.02572 seconds
Time After: 0.02611 seconds
Time Before: 0.02879 seconds
Time After: 0.03017 seconds
Time Taken: 0.00138 seconds
Time Before: 0.02501 seconds
Time After: 0.03043 seconds
Time Taken: 0.00542 seconds
Time Before: 0.04844 seconds
Time After: 0.04861 seconds
Time Before: 0.06238 seconds
Time After: 0.06384 seconds
Time Before: 0.07025 seconds
Time After: 0.07041 seconds
Time Before: 0.07245 seconds
Time After: 0.07389 seconds
UPDATE session SET lastactivity = 1772914129, location = '/forums/private.php?do=newpm&explain=1&u=68497' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.09073 seconds
Time After: 0.09105 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
