Time Before: 0.00143 seconds
Time After: 0.00190 seconds
Time Before: 0.00197 seconds
Time After: 0.00239 seconds
Time Before: 0.00266 seconds
Time After: 0.00285 seconds
Time Before: 0.00366 seconds
Time After: 0.00653 seconds
Time Taken: 0.00287 seconds
Time Before: 0.00293 seconds
Time After: 0.00994 seconds
Time Taken: 0.00701 seconds
Time Before: 0.01194 seconds
Time After: 0.01234 seconds
Time Before: 0.01503 seconds
Time After: 0.01626 seconds
Time Before: 0.01123 seconds
Time After: 0.01651 seconds
Time Taken: 0.00528 seconds
Time Before: 0.02264 seconds
Time After: 0.02283 seconds
Time Before: 0.08891 seconds
Time After: 0.09017 seconds
End call of global.php: 0.091984033584595
Time Before: 0.09336 seconds
Time After: 0.09349 seconds
Time Before: 0.09550 seconds
Time After: 0.09696 seconds
SET lastactivity = 1776871790, location = '/forums/private.php?do=newpm&explain=1&u=68514', badlocation = 1
Time Before: 0.10927 seconds
Time After: 0.10964 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.10836696624756 seconds with 9 queries, spending 0.0085151195526123 doing MySQL queries and 0.099851846694946 doing PHP things.
