Time Before: 0.00946 seconds
Time After: 0.01181 seconds
Time Taken: 0.00235 seconds
Time Before: 0.01190 seconds
Time After: 0.01228 seconds
Time Before: 0.01252 seconds
Time After: 0.01265 seconds
Time Before: 0.01339 seconds
Time After: 0.01590 seconds
Time Taken: 0.00251 seconds
Time Before: 0.01273 seconds
Time After: 0.01995 seconds
Time Taken: 0.00722 seconds
Time Before: 0.02358 seconds
Time After: 0.02396 seconds
Time Before: 0.02673 seconds
Time After: 0.02806 seconds
Time Taken: 0.00133 seconds
Time Before: 0.02289 seconds
Time After: 0.02827 seconds
Time Taken: 0.00538 seconds
Time Before: 0.04891 seconds
Time After: 0.04908 seconds
Time Before: 0.05580 seconds
Time After: 0.05708 seconds
End call of global.php: 0.059818029403687
Time Before: 0.06449 seconds
Time After: 0.06469 seconds
Time Before: 0.06750 seconds
Time After: 0.06911 seconds
Time Taken: 0.00161 seconds
SET lastactivity = 1783204211, location = '/forums/private.php?do=newpm&explain=1&u=68707', badlocation = 1
Time Before: 0.08814 seconds
Time After: 0.08844 seconds
Memory Before: 4,289.406 KB
Memory After: 4,289.617 KB
Page generated in 0.086939096450806 seconds with 9 queries, spending 0.0082762241363525 doing MySQL queries and 0.078662872314453 doing PHP things.
