Time Before: 0.00281 seconds
Time After: 0.00346 seconds
Time Taken: 0.00065 seconds
Memory Before: 1,246.203 KB
Memory After: 1,273.008 KB
Time Before: 0.00358 seconds
Time After: 0.00402 seconds
Memory Before: 1,272.969 KB
Memory After: 1,273.945 KB
Time Before: 0.00426 seconds
Time After: 0.00443 seconds
Memory Before: 1,274.586 KB
Memory After: 1,275.109 KB
Time Before: 0.00517 seconds
Time After: 0.00791 seconds
Time Taken: 0.00274 seconds
Memory Before: 1,277.977 KB
Memory After: 1,278.898 KB
Time Before: 0.00448 seconds
Time After: 0.01126 seconds
Time Taken: 0.00677 seconds
Memory Before: 1,274.391 KB
Memory After: 2,355.609 KB
Memory Used: 1,081.219 KB
Time Before: 0.01309 seconds
Time After: 0.01329 seconds
Memory Before: 2,895.875 KB
Memory After: 2,896.492 KB
Time Before: 0.01561 seconds
Time After: 0.01713 seconds
Time Taken: 0.00152 seconds
Memory Before: 2,908.203 KB
Memory After: 2,908.063 KB
Time Before: 0.01252 seconds
Time After: 0.01731 seconds
Time Taken: 0.00479 seconds
Memory Before: 2,888.602 KB
Memory After: 3,021.133 KB
Memory Used: 132.531 KB
Time Before: 0.02341 seconds
Time After: 0.02358 seconds
Memory Before: 3,655.680 KB
Memory After: 3,656.195 KB
Time Before: 0.03052 seconds
Time After: 0.03179 seconds
Memory Before: 4,133.273 KB
Memory After: 4,133.867 KB
End call of global.php: 0.033447027206421
Time Before: 0.03978 seconds
Time After: 0.03998 seconds
Memory Before: 5,197.516 KB
Memory After: 5,325.859 KB
Time Before: 0.04218 seconds
Time After: 0.04364 seconds
Memory Before: 5,481.203 KB
Memory After: 5,610.805 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=68939', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.05689 seconds
Time After: 0.05743 seconds
Time Taken: 0.00053 seconds
Memory Before: 5,997.742 KB
Memory After: 5,997.969 KB
Page generated in 0.055892944335938 seconds with 9 queries, spending 0.0086932182312012 doing MySQL queries and 0.047199726104736 doing PHP things.
