Time Before: 0.00201 seconds
Time After: 0.00263 seconds
Time Taken: 0.00062 seconds
Time Before: 0.00273 seconds
Time After: 0.00338 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00366 seconds
Time After: 0.00377 seconds
Time Before: 0.00451 seconds
Time After: 0.00709 seconds
Time Taken: 0.00258 seconds
Time Before: 0.00382 seconds
Time After: 0.01051 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01220 seconds
Time After: 0.01266 seconds
Time Before: 0.01570 seconds
Time After: 0.01702 seconds
Time Taken: 0.00132 seconds
Time Before: 0.01167 seconds
Time After: 0.01729 seconds
Time Taken: 0.00561 seconds
Time Before: 0.02352 seconds
Time After: 0.02368 seconds
Time Before: 0.02593 seconds
Time After: 0.02724 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.028897047042847
Time Before: 0.03006 seconds
Time After: 0.03022 seconds
Time Before: 0.03225 seconds
Time After: 0.03372 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=68944'
Time Before: 0.04842 seconds
Time After: 0.04864 seconds
Memory Before: 4,287.734 KB
Memory After: 4,287.977 KB
Page generated in 0.047514915466309 seconds with 9 queries, spending 0.0084481239318848 doing MySQL queries and 0.039066791534424 doing PHP things.
