Time Before: 0.00649 seconds
Time After: 0.01062 seconds
Time Taken: 0.00413 seconds
Time Before: 0.01071 seconds
Time After: 0.01159 seconds
Time Taken: 0.00087 seconds
Time Before: 0.01195 seconds
Time After: 0.01210 seconds
Time Before: 0.01289 seconds
Time After: 0.01535 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01216 seconds
Time After: 0.01943 seconds
Time Taken: 0.00728 seconds
Time Before: 0.02438 seconds
Time After: 0.02478 seconds
Time Before: 0.02708 seconds
Time After: 0.02826 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02365 seconds
Time After: 0.02846 seconds
Time Taken: 0.00481 seconds
Time Before: 0.04466 seconds
Time After: 0.04485 seconds
Time Before: 0.05637 seconds
Time After: 0.05777 seconds
Time Taken: 0.00140 seconds
End call of global.php: 0.060158014297485
Time Before: 0.06456 seconds
Time After: 0.06476 seconds
Time Before: 0.06726 seconds
Time After: 0.06889 seconds
Time Taken: 0.00163 seconds
SET lastactivity = 1784841119, location = '/forums/private.php?do=newpm&explain=1&u=68961', badlocation = 1
Time Before: 0.08572 seconds
Time After: 0.08603 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.084597110748291 seconds with 9 queries, spending 0.0087859630584717 doing MySQL queries and 0.075811147689819 doing PHP things.
