Time Before: 0.00475 seconds
Time After: 0.00566 seconds
Time Taken: 0.00092 seconds
Time Before: 0.00576 seconds
Time After: 0.00641 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00674 seconds
Time After: 0.00688 seconds
Time Before: 0.00777 seconds
Time After: 0.01043 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00693 seconds
Time After: 0.01382 seconds
Time Taken: 0.00689 seconds
Time Before: 0.01558 seconds
Time After: 0.01599 seconds
Time Before: 0.01888 seconds
Time After: 0.02010 seconds
Time Before: 0.01498 seconds
Time After: 0.02028 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02753 seconds
Time After: 0.02766 seconds
Time Before: 0.03092 seconds
Time After: 0.03222 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.034491062164307
Time Before: 0.03649 seconds
Time After: 0.03663 seconds
Time Before: 0.03931 seconds
Time After: 0.04076 seconds
SET lastactivity = 1776892668, location = '/forums/private.php?do=newpm&explain=1&u=69081', badlocation = 1
Time Before: 0.05543 seconds
Time After: 0.05581 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.054408073425293 seconds with 9 queries, spending 0.0084922313690186 doing MySQL queries and 0.045915842056274 doing PHP things.
