Time Before: 0.00172 seconds
Time After: 0.00231 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00242 seconds
Time After: 0.00301 seconds
Time Before: 0.00324 seconds
Time After: 0.00340 seconds
Time Before: 0.00411 seconds
Time After: 0.00656 seconds
Time Taken: 0.00246 seconds
Time Before: 0.00345 seconds
Time After: 0.00995 seconds
Time Taken: 0.00650 seconds
Time Before: 0.01192 seconds
Time After: 0.01246 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01578 seconds
Time After: 0.01743 seconds
Time Taken: 0.00165 seconds
Time Before: 0.01124 seconds
Time After: 0.01764 seconds
Time Taken: 0.00640 seconds
Time Before: 0.02300 seconds
Time After: 0.02320 seconds
Time Before: 0.02548 seconds
Time After: 0.02675 seconds
End call of global.php: 0.028397083282471
Time Before: 0.02980 seconds
Time After: 0.02996 seconds
Time Before: 0.03245 seconds
Time After: 0.03389 seconds
SET lastactivity = 1783080967, location = '/forums/private.php?do=newpm&explain=1&u=69086', badlocation = 1
Time Before: 0.04645 seconds
Time After: 0.04674 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.045552015304565 seconds with 9 queries, spending 0.0087547302246094 doing MySQL queries and 0.036797285079956 doing PHP things.
