Time Before: 0.03454 seconds
Time After: 0.04258 seconds
Time Taken: 0.00804 seconds
Time Before: 0.04270 seconds
Time After: 0.04316 seconds
Time Before: 0.04344 seconds
Time After: 0.04359 seconds
Time Before: 0.04447 seconds
Time After: 0.04667 seconds
Time Taken: 0.00220 seconds
Time Before: 0.04367 seconds
Time After: 0.05082 seconds
Time Taken: 0.00715 seconds
Time Before: 0.05941 seconds
Time After: 0.05986 seconds
Time Before: 0.06261 seconds
Time After: 0.06382 seconds
Time Before: 0.05878 seconds
Time After: 0.06401 seconds
Time Taken: 0.00522 seconds
Time Before: 0.11192 seconds
Time After: 0.11205 seconds
Time Before: 0.13191 seconds
Time After: 0.13317 seconds
Time Before: 0.14741 seconds
Time After: 0.14758 seconds
Time Before: 0.14989 seconds
Time After: 0.15132 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=69100', badlocation = 1 WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.16711 seconds
Time After: 0.16736 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
