Time Before: 0.00176 seconds
Time After: 0.00254 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00261 seconds
Time After: 0.00409 seconds
Time Before: 0.00442 seconds
Time After: 0.00457 seconds
Time Before: 0.00541 seconds
Time After: 0.00901 seconds
Time Taken: 0.00360 seconds
Time Before: 0.00463 seconds
Time After: 0.01238 seconds
Time Taken: 0.00775 seconds
Time Before: 0.01425 seconds
Time After: 0.01475 seconds
Time Before: 0.01753 seconds
Time After: 0.01892 seconds
Time Taken: 0.00139 seconds
Time Before: 0.01366 seconds
Time After: 0.01919 seconds
Time Taken: 0.00553 seconds
Time Before: 0.02518 seconds
Time After: 0.02563 seconds
Time Before: 0.02746 seconds
Time After: 0.02869 seconds
Time Before: 0.03183 seconds
Time After: 0.03198 seconds
Time Before: 0.03411 seconds
Time After: 0.03551 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=69203', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04966 seconds
Time After: 0.04996 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
