Time Before: 0.00165 seconds
Time After: 0.00218 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00225 seconds
Time After: 0.00265 seconds
Time Before: 0.00290 seconds
Time After: 0.00304 seconds
Time Before: 0.00389 seconds
Time After: 0.00657 seconds
Time Taken: 0.00268 seconds
Time Before: 0.00312 seconds
Time After: 0.00993 seconds
Time Taken: 0.00681 seconds
Time Before: 0.01174 seconds
Time After: 0.01214 seconds
Time Before: 0.01522 seconds
Time After: 0.01652 seconds
Time Before: 0.01115 seconds
Time After: 0.01676 seconds
Time Taken: 0.00560 seconds
Time Before: 0.02291 seconds
Time After: 0.02311 seconds
Time Before: 0.02558 seconds
Time After: 0.02679 seconds
End call of global.php: 0.028426170349121
Time Before: 0.02977 seconds
Time After: 0.02993 seconds
Time Before: 0.03292 seconds
Time After: 0.03442 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1789114006, location = '/forums/private.php?do=newpm&explain=1&u=69270', badlocation = 1
Time Before: 0.04877 seconds
Time After: 0.04910 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.047346115112305 seconds with 9 queries, spending 0.0083200931549072 doing MySQL queries and 0.039026021957397 doing PHP things.
