Time Before: 0.03493 seconds
Time After: 0.04263 seconds
Time Taken: 0.00770 seconds
Time Before: 0.04273 seconds
Time After: 0.04315 seconds
Time Before: 0.04340 seconds
Time After: 0.04358 seconds
Time Before: 0.04429 seconds
Time After: 0.04675 seconds
Time Taken: 0.00246 seconds
Time Before: 0.04364 seconds
Time After: 0.05055 seconds
Time Taken: 0.00691 seconds
Time Before: 0.05868 seconds
Time After: 0.05908 seconds
Time Before: 0.06180 seconds
Time After: 0.06311 seconds
Time Taken: 0.00131 seconds
Time Before: 0.05798 seconds
Time After: 0.06330 seconds
Time Taken: 0.00532 seconds
Time Before: 0.10138 seconds
Time After: 0.10157 seconds
Time Before: 0.11978 seconds
Time After: 0.12104 seconds
Time Before: 0.13288 seconds
Time After: 0.13304 seconds
Time Before: 0.13562 seconds
Time After: 0.13705 seconds
UPDATE session SET lastactivity = 1782960520, location = '/forums/private.php?do=newpm&explain=1&u=69314', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.15648 seconds
Time After: 0.15677 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
