Time Before: 0.00164 seconds
Time After: 0.00218 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00225 seconds
Time After: 0.00279 seconds
Time Before: 0.00301 seconds
Time After: 0.00316 seconds
Time Before: 0.00399 seconds
Time After: 0.00663 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00326 seconds
Time After: 0.01233 seconds
Time Taken: 0.00908 seconds
Time Before: 0.01498 seconds
Time After: 0.01539 seconds
Time Before: 0.01725 seconds
Time After: 0.01848 seconds
Time Before: 0.01416 seconds
Time After: 0.01867 seconds
Time Taken: 0.00451 seconds
Time Before: 0.02395 seconds
Time After: 0.02412 seconds
Time Before: 0.02665 seconds
Time After: 0.02786 seconds
End call of global.php: 0.030615091323853
Time Before: 0.03192 seconds
Time After: 0.03206 seconds
Time Before: 0.03501 seconds
Time After: 0.03644 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=69319', badlocation = 1
Time Before: 0.05067 seconds
Time After: 0.05089 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
Page generated in 0.049744129180908 seconds with 9 queries, spending 0.0081441402435303 doing MySQL queries and 0.041599988937378 doing PHP things.
