Time Before: 0.00137 seconds
Time After: 0.00197 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00204 seconds
Time After: 0.00252 seconds
Time Before: 0.00276 seconds
Time After: 0.00289 seconds
Time Before: 0.00384 seconds
Time After: 0.00644 seconds
Time Taken: 0.00259 seconds
Time Before: 0.00295 seconds
Time After: 0.01083 seconds
Time Taken: 0.00788 seconds
Time Before: 0.01264 seconds
Time After: 0.01316 seconds
Time Before: 0.01653 seconds
Time After: 0.01774 seconds
Time Before: 0.01202 seconds
Time After: 0.01797 seconds
Time Taken: 0.00595 seconds
Time Before: 0.02339 seconds
Time After: 0.02351 seconds
Time Before: 0.02547 seconds
Time After: 0.02667 seconds
End call of global.php: 0.028388977050781
Time Before: 0.02976 seconds
Time After: 0.02994 seconds
Time Before: 0.03234 seconds
Time After: 0.03382 seconds
SET lastactivity = 1785290414, location = '/forums/private.php?do=newpm&explain=1&u=69353', badlocation = 1
Time Before: 0.04792 seconds
Time After: 0.05001 seconds
Time Taken: 0.00209 seconds
Memory Before: 4,912.227 KB
Memory After: 4,912.438 KB
Page generated in 0.046998977661133 seconds with 9 queries, spending 0.010009527206421 doing MySQL queries and 0.036989450454712 doing PHP things.
