Time Before: 0.00237 seconds
Time After: 0.00294 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00300 seconds
Time After: 0.00348 seconds
Time Before: 0.00376 seconds
Time After: 0.00393 seconds
Time Before: 0.00478 seconds
Time After: 0.00738 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00400 seconds
Time After: 0.01151 seconds
Time Taken: 0.00751 seconds
Time Before: 0.01403 seconds
Time After: 0.01444 seconds
Time Before: 0.01708 seconds
Time After: 0.01838 seconds
Time Before: 0.01328 seconds
Time After: 0.01863 seconds
Time Taken: 0.00535 seconds
Time Before: 0.02599 seconds
Time After: 0.02616 seconds
Time Before: 0.02853 seconds
Time After: 0.02982 seconds
End call of global.php: 0.032828092575073
Time Before: 0.03480 seconds
Time After: 0.03500 seconds
Time Before: 0.03786 seconds
Time After: 0.03943 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1789024006, location = '/forums/private.php?do=newpm&explain=1&u=69450'
Time Before: 0.05983 seconds
Time After: 0.06042 seconds
Time Taken: 0.00059 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.058511972427368 seconds with 9 queries, spending 0.0087530612945557 doing MySQL queries and 0.049758911132812 doing PHP things.
