Time Before: 0.00139 seconds
Time After: 0.00184 seconds
Time Before: 0.00191 seconds
Time After: 0.00246 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00272 seconds
Time After: 0.00282 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00350 seconds
Time After: 0.00627 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00287 seconds
Time After: 0.00985 seconds
Time Taken: 0.00698 seconds
Time Before: 0.01184 seconds
Time After: 0.01212 seconds
Time Before: 0.01451 seconds
Time After: 0.01567 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01120 seconds
Time After: 0.01584 seconds
Time Taken: 0.00465 seconds
Time Before: 0.02118 seconds
Time After: 0.02137 seconds
Time Before: 0.02365 seconds
Time After: 0.02496 seconds
Time Before: 0.02879 seconds
Time After: 0.02896 seconds
Time Before: 0.03110 seconds
Time After: 0.03253 seconds
UPDATE session SET lastactivity = 1780622498, location = '/forums/private.php?do=newpm&explain=1&u=69521', badlocation = 1 WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04514 seconds
Time After: 0.04549 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
