Time Before: 0.00129 seconds
Time After: 0.00171 seconds
Time Before: 0.00178 seconds
Time After: 0.00222 seconds
Time Before: 0.00243 seconds
Time After: 0.00257 seconds
Time Before: 0.00327 seconds
Time After: 0.00592 seconds
Time Taken: 0.00264 seconds
Time Before: 0.00261 seconds
Time After: 0.00931 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01119 seconds
Time After: 0.01174 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01392 seconds
Time After: 0.01513 seconds
Time Before: 0.01052 seconds
Time After: 0.01530 seconds
Time Taken: 0.00478 seconds
Time Before: 0.02022 seconds
Time After: 0.02044 seconds
Time Before: 0.02260 seconds
Time After: 0.02382 seconds
End call of global.php: 0.025429964065552
Time Before: 0.02695 seconds
Time After: 0.02709 seconds
Time Before: 0.02919 seconds
Time After: 0.03133 seconds
Time Taken: 0.00214 seconds
SET lastactivity = 1788845748, location = '/forums/private.php?do=newpm&explain=1&u=69527'
Time Before: 0.04351 seconds
Time After: 0.04392 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
Page generated in 0.042623043060303 seconds with 9 queries, spending 0.0091092586517334 doing MySQL queries and 0.033513784408569 doing PHP things.
