Time Before: 0.01684 seconds
Time After: 0.02359 seconds
Time Taken: 0.00674 seconds
Time Before: 0.02368 seconds
Time After: 0.02405 seconds
Time Before: 0.02427 seconds
Time After: 0.02441 seconds
Time Before: 0.02521 seconds
Time After: 0.02712 seconds
Time Taken: 0.00191 seconds
Time Before: 0.02446 seconds
Time After: 0.03119 seconds
Time Taken: 0.00673 seconds
Time Before: 0.03734 seconds
Time After: 0.03770 seconds
Time Before: 0.04010 seconds
Time After: 0.04129 seconds
Time Before: 0.03667 seconds
Time After: 0.04148 seconds
Time Taken: 0.00481 seconds
Time Before: 0.07463 seconds
Time After: 0.07481 seconds
Time Before: 0.50811 seconds
Time After: 0.50947 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.51163101196289
Time Before: 0.52013 seconds
Time After: 0.52029 seconds
Time Before: 0.52261 seconds
Time After: 0.52404 seconds
SET lastactivity = 1776646688, location = '/forums/private.php?do=newpm&explain=1&u=69557', badlocation = 1
Time Before: 0.54165 seconds
Time After: 0.54190 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
Page generated in 0.5406711101532 seconds with 9 queries, spending 0.0073482990264893 doing MySQL queries and 0.53332281112671 doing PHP things.
