Time Before: 0.01135 seconds
Time After: 0.01538 seconds
Time Taken: 0.00403 seconds
Time Before: 0.01546 seconds
Time After: 0.01587 seconds
Time Before: 0.01614 seconds
Time After: 0.01627 seconds
Time Before: 0.01698 seconds
Time After: 0.01976 seconds
Time Taken: 0.00279 seconds
Time Before: 0.01635 seconds
Time After: 0.02446 seconds
Time Taken: 0.00810 seconds
Time Before: 0.03065 seconds
Time After: 0.03105 seconds
Time Before: 0.03351 seconds
Time After: 0.03473 seconds
Time Before: 0.02998 seconds
Time After: 0.03494 seconds
Time Taken: 0.00497 seconds
Time Before: 0.05695 seconds
Time After: 0.05710 seconds
Time Before: 0.06904 seconds
Time After: 0.07030 seconds
Time Before: 0.07851 seconds
Time After: 0.07877 seconds
Time Before: 0.08128 seconds
Time After: 0.08282 seconds
Time Taken: 0.00154 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=69572', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.10458 seconds
Time After: 0.10487 seconds
Memory Before: 4,288.016 KB
Memory After: 4,288.242 KB
