Time Before: 0.00715 seconds
Time After: 0.00956 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00963 seconds
Time After: 0.00995 seconds
Time Before: 0.01012 seconds
Time After: 0.01027 seconds
Time Before: 0.01109 seconds
Time After: 0.01435 seconds
Time Taken: 0.00325 seconds
Time Before: 0.01032 seconds
Time After: 0.01905 seconds
Time Taken: 0.00874 seconds
Time Before: 0.02422 seconds
Time After: 0.02463 seconds
Time Before: 0.02710 seconds
Time After: 0.02834 seconds
Time Before: 0.02346 seconds
Time After: 0.02857 seconds
Time Taken: 0.00511 seconds
Time Before: 0.04238 seconds
Time After: 0.04252 seconds
Time Before: 0.04896 seconds
Time After: 0.05018 seconds
Time Before: 0.05646 seconds
Time After: 0.05659 seconds
Time Before: 0.05930 seconds
Time After: 0.06073 seconds
UPDATE session SET lastactivity = 1772641326, location = '/forums/private.php?do=newpm&explain=1&u=69576' WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.07583 seconds
Time After: 0.07615 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
