Time Before: 0.01129 seconds
Time After: 0.01474 seconds
Time Taken: 0.00345 seconds
Time Before: 0.01487 seconds
Time After: 0.01542 seconds
Time Taken: 0.00055 seconds
Time Before: 0.01569 seconds
Time After: 0.01593 seconds
Time Before: 0.01687 seconds
Time After: 0.01909 seconds
Time Taken: 0.00222 seconds
Time Before: 0.01601 seconds
Time After: 0.02260 seconds
Time Taken: 0.00660 seconds
Time Before: 0.02658 seconds
Time After: 0.02689 seconds
Time Before: 0.03005 seconds
Time After: 0.03123 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02583 seconds
Time After: 0.03144 seconds
Time Taken: 0.00561 seconds
Time Before: 0.04739 seconds
Time After: 0.04752 seconds
Time Before: 0.05657 seconds
Time After: 0.05783 seconds
Time Before: 0.06457 seconds
Time After: 0.06473 seconds
Time Before: 0.06776 seconds
Time After: 0.06966 seconds
Time Taken: 0.00190 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=69632', badlocation = 1 WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.08855 seconds
Time After: 0.08886 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
