Time Before: 0.01621 seconds
Time After: 0.02151 seconds
Time Taken: 0.00530 seconds
Time Before: 0.02162 seconds
Time After: 0.02212 seconds
Time Before: 0.02237 seconds
Time After: 0.02250 seconds
Time Before: 0.02322 seconds
Time After: 0.02558 seconds
Time Taken: 0.00236 seconds
Time Before: 0.02255 seconds
Time After: 0.02961 seconds
Time Taken: 0.00707 seconds
Time Before: 0.03732 seconds
Time After: 0.03750 seconds
Time Before: 0.03895 seconds
Time After: 0.04035 seconds
Time Taken: 0.00140 seconds
Time Before: 0.03663 seconds
Time After: 0.04057 seconds
Time Taken: 0.00394 seconds
Time Before: 0.07371 seconds
Time After: 0.07384 seconds
Time Before: 0.08608 seconds
Time After: 0.08739 seconds
Time Taken: 0.00131 seconds
Time Before: 0.09855 seconds
Time After: 0.09873 seconds
Time Before: 0.10180 seconds
Time After: 0.10342 seconds
Time Taken: 0.00161 seconds
UPDATE session SET lastactivity = 1776710691, location = '/forums/private.php?do=newpm&explain=1&u=69709', badlocation = 1 WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.11956 seconds
Time After: 0.13183 seconds
Time Taken: 0.01227 seconds
Memory Before: 4,288.594 KB
Memory After: 4,288.805 KB
