Time Before: 0.01760 seconds
Time After: 0.02377 seconds
Time Taken: 0.00617 seconds
Time Before: 0.02423 seconds
Time After: 0.02569 seconds
Time Before: 0.02597 seconds
Time After: 0.02611 seconds
Time Before: 0.02710 seconds
Time After: 0.02978 seconds
Time Taken: 0.00267 seconds
Time Before: 0.02620 seconds
Time After: 0.03564 seconds
Time Taken: 0.00945 seconds
Time Before: 0.04356 seconds
Time After: 0.04377 seconds
Time Before: 0.04701 seconds
Time After: 0.04822 seconds
Time Before: 0.04280 seconds
Time After: 0.04850 seconds
Time Taken: 0.00570 seconds
Time Before: 0.08960 seconds
Time After: 0.08975 seconds
Time Before: 0.10620 seconds
Time After: 0.10744 seconds
Time Before: 0.11801 seconds
Time After: 0.11817 seconds
Time Before: 0.12063 seconds
Time After: 0.12208 seconds
UPDATE session SET lastactivity = 1776626767, location = '/forums/private.php?do=newpm&explain=1&u=6971' WHERE sessionhash = '0072f2714e5608fd7a8a8d7024a3e041'
Time Before: 0.14135 seconds
Time After: 0.14162 seconds
Memory Before: 4,911.164 KB
Memory After: 4,911.383 KB
