Time Before: 0.01062 seconds
Time After: 0.01396 seconds
Time Taken: 0.00334 seconds
Time Before: 0.01407 seconds
Time After: 0.01466 seconds
Time Taken: 0.00059 seconds
Time Before: 0.01488 seconds
Time After: 0.01503 seconds
Time Before: 0.01581 seconds
Time After: 0.01835 seconds
Time Taken: 0.00255 seconds
Time Before: 0.01510 seconds
Time After: 0.02297 seconds
Time Taken: 0.00787 seconds
Time Before: 0.02818 seconds
Time After: 0.02878 seconds
Time Before: 0.03127 seconds
Time After: 0.03244 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02759 seconds
Time After: 0.03268 seconds
Time Taken: 0.00509 seconds
Time Before: 0.05522 seconds
Time After: 0.05577 seconds
Time Taken: 0.00055 seconds
Time Before: 0.07375 seconds
Time After: 0.07520 seconds
Time Before: 0.08177 seconds
Time After: 0.08194 seconds
Time Before: 0.08458 seconds
Time After: 0.08603 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=69897', badlocation = 1 WHERE sessionhash = '4107984102e2914075bf6bfb65da9afe'
Time Before: 0.10303 seconds
Time After: 0.10326 seconds
Memory Before: 4,911.938 KB
Memory After: 4,912.164 KB
