Time Before: 0.00197 seconds
Time After: 0.00257 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00265 seconds
Time After: 0.00316 seconds
Time Before: 0.00337 seconds
Time After: 0.00352 seconds
Time Before: 0.00435 seconds
Time After: 0.00706 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00356 seconds
Time After: 0.01197 seconds
Time Taken: 0.00840 seconds
Time Before: 0.01417 seconds
Time After: 0.01454 seconds
Time Before: 0.01690 seconds
Time After: 0.01813 seconds
Time Before: 0.01359 seconds
Time After: 0.01831 seconds
Time Taken: 0.00471 seconds
Time Before: 0.02347 seconds
Time After: 0.02368 seconds
Time Before: 0.02569 seconds
Time After: 0.02692 seconds
Time Before: 0.02968 seconds
Time After: 0.02983 seconds
Time Before: 0.03178 seconds
Time After: 0.03317 seconds
Time Taken: 0.00139 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=6992', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.04550 seconds
Time After: 0.04576 seconds
Memory Before: 4,911.086 KB
Memory After: 4,911.313 KB
