Time Before: 0.00755 seconds
Time After: 0.01023 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01036 seconds
Time After: 0.01162 seconds
Time Before: 0.01191 seconds
Time After: 0.01209 seconds
Time Before: 0.01300 seconds
Time After: 0.01529 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01217 seconds
Time After: 0.02027 seconds
Time Taken: 0.00810 seconds
Time Before: 0.02425 seconds
Time After: 0.02462 seconds
Time Before: 0.02706 seconds
Time After: 0.02832 seconds
Time Before: 0.02358 seconds
Time After: 0.02853 seconds
Time Taken: 0.00495 seconds
Time Before: 0.05104 seconds
Time After: 0.05121 seconds
Time Before: 0.05724 seconds
Time After: 0.05847 seconds
Time Before: 0.06513 seconds
Time After: 0.06535 seconds
Time Before: 0.06801 seconds
Time After: 0.06952 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=6999' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.08894 seconds
Time After: 0.08924 seconds
Memory Before: 4,910.797 KB
Memory After: 4,911.047 KB
Memory Used: 0.250 KB
